Hi Everyone,
We haveRe-defined 68 Wireless Keyboard Kit in stock.
Specification information:
Available Colors : White, Grey, Milky-White
Price: USD$60.44 (10% OFF for your first order)
Specifications:
- Size: 308.6118.6039.2MM
- weight: 432g (Without Switches and keycaps)
- Keying Height: 28mm
- Keying Angle: 4°/7°
- Material: Aluminum+ ABS
- Plate material: Steel
- Silencer Pad: Silicone
- Case foam: Sponges
- Rated input:
- wired: 5V ±0.25V (RGB)
- wireless: 3.7V<180mA (RGB)
- Battery Capacity: 2000mA
GIVEAWAY:
- Prizes: Re-defined 68 Wireless Keyboard Kit for one winner
- How to join: Power User Program – MARVODIY
- Time: Giveaway ends on November 22, the winner will be announced on email.
Thank you for reading this post! Good luck with the giveaway!
