First impressions of Hexgears/Hyeku e2s Pro 75%
Hi guys so my Hexgears/Hyeku e2s pro was delivered today and this is first impression.
Looks : In my humble opinion this board looks great! Although the key profile says its cherry, but is a bit flat compared to other “cherry” profiles I have used. The RGB shines bright enough to be seen in mid day sun with the shades open the pictures featured are in full days sun. I am not a fan of the gold knob though, in my opinion it doesn’t fit the build. The bronze or gold color just doesn’t match the rest of the board. I also find it quite odd that only the esc, space and enter are a different color. I am guessing they did it to add some contrast but they look out of place IMO just like the volume rocker but at this price point (Sub 30 USD) I don’t think you can expect too much. It comes with a magnetic wrist rest, and looks good attached to the keyboard and it doesn’t detach really easy like a few I have tried before. If I could of had a choice I would of rather them spend the money and time they did on the wrist rest on a more diverse selection of keycaps and or a better knob.
Feel : This board comes preinstalled with Crimson cream cloud switches and they are some of the most quiet and comfortable I have ever used. I can see myself using these switches daily for long typing sessions or for gaming. But that can also be due to the dampening and stability material in the board I’ll have to remove them and put them in another board to test that (coming soon). The entire case is made out of plastic but there is no real flex in the board as I tried to twist it top to bottom and side to side and got 0 flex so its sturdy enough for everyday use. There are a lot of shortcuts on the keyboard, everything from mouse movement, media control, windows/mac swap, Lock keys, battery, and more. The volume rocker seems decent but the shank is made out of plastic and I believe it will fit any 6.1-6.5 mm maybe bigger diameter Knob as long as it has a setscrew in it but I’ll have to wait until mine get here to test that out. The included magnetic wrist rest is a nice addition at this price point but feels extremely cheap gets tacky when your using it, and I don’t see myself using it for any extended length of time (idk about you guys but when I have shiny cheap plastic stick to my wrists as I’m moving my hands around typing it just makes me cringe but that’s probably that’s just a me thing I’m sure someone likes it). The usb-c cord is a soft pliable material which kind of surprised me because I have had several Hexgears now and this is the first one that didn’t include a braded cable. But at this price point you really have to cut corners where you can so its understandable and easily replaceable if its not your thing.
Features : This board is absolutely packed with features for this price point (Sub 30 USD), it has 3 different connection types including USB-C, BT 5.0, and 2.4 GHZ Dongle that a holder is built into the right side for storage. The bluetooth also includes 3 savable profiles so you can have 3 different devices saved at once and don’t have to pair every time you want to change devices. The RGB in my opinion is a little lack luster on the colors but it claims it includes16.8m colors, 18 lighting modes and a custom driver and software that I have not tried yet (that may be why the colors are a little lack luster to me) that allows for a lot more customization. It includes things like a radiant heart​:heart:, and boasts no glare RGB. The keys feature Double shot PBT and shine through but none of the keyboard shortcuts are shine through so it makes it hard to use those in the dark. It is hot swappable with both 3 and 5 pin MX switches and has single slot PCB, and stabilization support and sound dampening materials including a extended integrated silicone pad. Three layers of “silencer” filling that fills the gap between the PCB the positioning plate and the shaft. Virtually eliminating any cavity noise you would experience with most other keyboards in this price range and providing a sturdy and solid key travel.
Conclusion : I like this board and I spent a few weeks researching this price point and IMO its one of the most feature rich lovely keyboards I have gotten at this price point and I’ve spent a lot of money on boards in the past. Everything from a Corsair K70 mk2 Special edition (cherry silvers) to cheap budget mechanical boards. But this is my first experience with a hot swappable board and I am excited to try out some upgrades on it. Coming soon I plan on doing a tear down, sound test with different switches, and upgrades. I will be posting about those as they develop, thank you for taking the time to read this and if you are in the market for a decent board for a great price IMO this board is a no brainer.
