Hey y’all, been looking into building my first mechanical keyboard and wanted to get some community input as well as double checking part compatibility
I’ve outlined the following in terms of the board’s parts below:
I would try the switches w/o lube to see if you like them. Just put them in the board w/o soldiering and fake type on them for a day or so and see what you think.
You MUST lube the stabilizers for them to not have rattle. I use dielectric grease. You can use superlube. It needs to be thick. Same stuff for metal/plastic and plastic/plastic.
I’d recommend lubing any switches it just makes them feel/sound better. For lubing tactiles its better to avoid the actual tactile bump of the stem as that can “mute” and lessen the tactile feel
lube for the stabs is a must as the stabs as they can be the loudest/ annoying part of a good keyboard.
I’d recommend getting 3204 for switches and krytox 206 for stabs.
Oooh good call on the fake type strat, I’ll definitely give that a shot prior to lubing em up. And sounds good on the stabilizer lubing, I’ll look into dielectric grease/superlube (for the dielectric grease did you just get something like this?
