Since people seem to like “color matching”, here’s a quick snapshot with a 18% gray card (no processing done outside of a quick color correction).
Sorry for the CTRL, I know it’s not a “““custom””” for some people, but it was the nearest and quickest to dress up with these caps and I’m a bit busy right now.
And sorry for the dust, the CTRL is normally on my raspberry pi to control a CNC, and I’m making wood SA caps (“SA Oak”) these days… thus, dust.
And I’m also including a low depth of field for those maniacs who are in love with ridiculous amounts of blur.
My dude don’t worry about your keyboard. It’s a keyboard and this is a keyboard forum and I think most people here are just happy to see keyboards (unless it’s a rubber dome maybe). The high quality pics and color check are awesome. Do you worry about getting wood in the switches?
Not really, it’s easier to dust with a low profile, and those are box white, so it more dust proof than most switches.
Sadly I just destroyed a dz60rgb at work with static, so I’ll have to swap things around a bit. Probably get out an old roamer-g for the cnc, bring my other 60 at work, and put the CTRL on my main computer at home.
I electrocuted a lot of peripherals in my life. First time I kill one.
Oh dang, yeah, that’s actually probably one of the better keyboards to have there then.
Unfortunately there are a lot of keyboards floating around out there with ESD protection that is very poor to non-existent, it’s something that definitely makes me sad, because if you know what you need to do it is very easy to protect against.
