[GB] Fjell R5
Picture by /u/Kawamash
Shipping
We are trying to have a reasonable shipping cost for all our buyers, and will end up eating a bit of the cost to keep it as low as possible. Please keep in mind that this is a heavy product and will still cost a decent amount to ship around the world.
Updates in R5
New sandblasting methods for a finer finish
Better color consistency
New color (red)
Limited edition available
Updates in R4
You will be able to completely remove the spacebar and middle mounting points. This is to ensure compability with hotswap PCBs, and for those that prefer a more flexible typing experience. The inserts will be made in brass.
Other updates:
slight mounting changes
slight USB hole changes
FAQ
What is this case?
It is a tray mount case for 60 percent mechanical keyboards that follow the standarized Poker mounting. It has a weight of 2kg, or approx. 4.4 lbs.
When will it be available?
The pre order will start within a few weeks/days, depending on some final details from the factory regarding the Limited Edition Fjell.
What is the Limited Edition Fjell?
This Fjell will have a different material weight, and different engravings. We are doing this limited to test it out for use in further product development.
Will foam be available?
Yes, for $9, we will include 2x 2mm layers of medium-high density EVA foam.
Why are you running this now?
Please read this: https://mekanisk.co/blogs/updates/march-2-fjell-r5
Read complete blog post with FAQ
It will be available on this following link:
Any questions? Please let me know.
Awesome! I’m just over here waiting for the return of the Klippe S.
We are working on a lot of things for 2020, including the Klippe S.
thanks for your interest!
This pre order will go live 26.03 (that is Thursday next week).
Thank you.
https://mekanisk.com/
Timer is up!
Go to Mekanisk.com now.
Has the LE Fjell gone live? Haven’t seen it in stock yet.
yeah it went out in like 20 seconds. limited run of 10 units
8 hours left to get one! If you want one, get one now.
I will be closing then, due to a large amount of interest(and orders).
Klippe will still be available after that.
best of luck with it, man. I’m holding out strong for the Tind. It was really hard to hold off on the white Fjell, but times are tough at the moment.
Hey! That is totally understandable. Thanks for your support!
Dang, that window was so short! I really wanted to get in on this GB but missed it because I was welcoming my son to world yesterday! A little sad about missing it but happy at the same time about my priorities in life :smile:
Thanks for everyones support. Fjell R5 is closed, but you can still pick up a Klippe T kit.
