[gb] keeblade & zlant cases!
Hi there!
I’ve started a goupbuy a couple of days ago centered around the zlant and keeblades. Although the zlant pcb goupbuy is over i’m sure you can message ziptyze if you need a pcb. You can also just use a regular old 48key ortho pcb for all your keeblade needs!
Groupbuylink + information : goo.gl/forms/55jsUfipUPGbeZgu1
The groupbuy might close earlier because i want to be sure that i can deal with the amount of blades i need to produce. I wouldn’t want huge delays to come up! cheers!
You can also follow me on instagram.com/qlavier for every update on the keeblade and future projects!
