Hi Everyone,
Good day! The GB for the KK75 KEYBOARD KIT is NOW LIVE on the Website Here. You can also check our IC post.
High-Resolution Images here. Join our discord server here.
Spec:
Aluminum 6063
Type-C
Wired
Single backlight (Need to purchase and install switch LED yourself)
KK75 Software
-Remap keys
-Macro
-Musical rhythm: https://imgur.com/ebBbCip
Keyboard Angle: 4 degrees
Keyboard size: 327 * 170 * 32mm
Weight of the kit: 1.6 kg
The standard kit comes with:
Aluminum alloy case * 1 (top mount)
Non-hot-swap PCBA * 1
Aluminum Plate * 1
PCB Mounted Stabilizers
Default or custom name badge (PVD brass, shiny, screwed in, Size: 45.2*23.6 mm)
Price: US$170 + US$40 ( International DHL express) + PP fee. All prices included when placing order.
GB Open: June 12, 2020 – June 30, 2020.
MOQ: Already met at this moment in a small GB, so it’s not a problem
Estimated Delivery: Middle September 2020
Add on explanation
1. Upgrade Brass Plate : US$19.99 (No aluminum plate, but only one brass plate )
2. Extra Brass Plate : US$27.99 (One more brass plate plus aluminum plate / upgrade brass plate)
3. Extra PCB : US$29.99
Pls check and follow Custom name badge (PVD brass, Shiny) guide
1. Leave a note of the name badge option when placing order.
Option A: default letters “KK75”
Option B: custom to letters you want. No extra cost.
Option C: custom to image with extra US$10 (need to add “image name badge to cart”)
Option D: leave name badge blank
2. Send us JPG/PNG file with your order number (Order 8765 for example).
Filename : “Order 8765 custom name badge. jpg”
Email Subject : Order 8765 custom name badge
Email to : leonor@velocifiretech.com
If you have any questions, please feel free to comment. Thanks for everyone’s support!
