The Noxary T60 is a extremely simple tray mount case. The main feature is the lack of 2 center posts, creating a more flexible typing experience. This is compatible with the majority of tray mount builds, whether it’s USB C or Mini.
Nice, I was thinking about grabbing one of the new Klippes but I like the ideal of no center posts better! I got my ADK64 without a center a post & while that was a complete fail for ALPS based builds, it’s feel great to type on with MX based builds. Not sure why my ALPS64 build felt so wonky in the ADK64, but I have to put it down to the missing center post. I put it in my 5 degree case & it feels great again. I guess ALPS switches just need really stiff setups?
Was thinking about joining, but it looks like the plate is sold out while there are still spots for the case. Seems a little weird, or am I missing something?
Also, I’m curious about why you didn’t post this to geekhack, or am I missing something again?
I’m sure that the plates are sold out so quick because people bought several at a time and they had the same max quantity as the cases. Being that they are polycarbonate, 5mm and universal didn’t help the low quality either. They should of had like a limit to the number that you could buy, like 1 plate per case or something.
Wow 7 hours, I thought that they would have sold out way before then. I assumed some one would have loaded up on plates. You don’t see many 5mm polycarbonate plates.
