Hey guys, just posting some feedback on Greentech Black switches I bought a while back from Novel Keys. I hadn’t seen them mentioned that often so I was curious to see how they stacked up to some of the other linear switches I’m currently using like retooled blacks, Gateron blacks/yellows and inks.
My initial thoughts are they’re a damn good value for the money. Exceptionally smooth, decent weighting and interesting sound profile. The only fault I can find is the springs are a little on the thin/cheap side but with a touch of lube they’re fine.
Has anyone else has given them a try? I’m interested in your thoughts. Also has anyone tried a spring swap? If so, which springs? I think a slightly lighter spring would put them right in my sweet spot for linears.
