Guys I need help to fix this keyboard
Honestly yeah I’d probably just grab the Lemokey; it has more capacity for repair and maintenance if the same thing ever happens to it. Most keyboards come with a key-puller tool and sometimes a dust cover now, but you can get one cheap if not.
While you’re waiting on it you could try putting some lubricant on the parts of the old keys that slot-into the keyboard - though I wouldn’t use WD-40. Maybe some bicycle chain drip lube like White Lightning (because it’s easy to find at a department store and it works in a pinch) in lieu of the PTFE Krytox oil we’d usually use for keebs. Just some dripped on a q-tip and swabbed onto the surfaces that rub-against eachother.
Okay maybe I’ll try it lol idk
Also guys what’s the difference between the Lemo key x3 and x2 or is their a difference?
I actually googled it last night. I think the X3 is a typical “high profile” case where it comes up a little and conceals the lower sides of the switches. The X2 looks to be MADE as a low profile CASE (not to be confused with low profile keycaps or switches), possibly with a little clip or magnetic shroud to replicate the high profile look. It could affect feel and sound, I saw one review suggesting the X3 was disconcertingly “floaty” and an old-design steel plate low profile case would be more rigid, past the point where some people would prefer it. In this price range I don’t know that I’d get overly worried about it as long as it looks nice to you. You’ll be learning if this whole mechanical keyboard thing is even a big deal to you at all, and it’s really hard to say at first exactly what you’ll prefer.
I also think the X2 is cheaper, lol.
Oh yea well on their website the x3 is like 37 dollars
But on Amazon the x2 is like 32 dollars
But idk what is the differences if their aren’t really any because they do look the same so yeah
But I think I’ll buy the x2 I guess from Amazon because it will arrive sooner I’m sure
As as for my old keyboard r.i.p you done me a solid 2 years lol
