I’m planning on modding Kailh Speed Gold Stems into Nolive Kailh POM Housings from Novelkeys…
This should work, right? 63.5g Speed gamer switches that are a little bit louder… even though I have the same thing in Outemu Sky already
Will report back if they work.
Plus gold stem + olive housing = Jon Snow
Wait, outemu sky housings are pom?
No, Outemu Sky housings are polycarbonate, last I knew of them.
I don’t like all the work that those pom switches take. They need lube, but even worse, the top and bottom housing aren’t super tight and creak. You either have to add switch films or put some lube between the top and bottom edges. It’s a pain. I’m assuming the nolive switches use the same molds, right?
Can’t think of any reason this wouldn’t work, I bet it’ll look pretty sweet too!
