Are there any decent keycaps with translucent legends?
I have some that came with cheap keyboards, but the keycaps are very thin and the legends are horrifying.
All recommendations are very much appreciated.
fkcaps does custom shine-through in a few different profiles. That might be an improvement.
If it’s a totally standard layout like a traditional 104-key or TKL, Ducky makes some decent quality shine through caps - but the compatibility for other layouts is pretty much nil.
Don’t know what quality you’re thinking of when you mention decent, but if you want an upgrade over standard OEM ABS shine through keycaps, their are always PBT options
Still with OEM profile, but you with PBT the sound will change slightly and it won’t shine as quickly as ABS
Those do look nice!
I’m really hoping GMK will one day take a longer step into this realm. Seems like we’ve gone way too long with poorly implemented shine-through keycaps.
Actually the HyperX Pudding Keycaps are really good, I don’t now what y’all think about them but I mean I think they are pretty good
I think those look good for the aesthetic they are targeting, but I’m looking for crisp legends with minimal light bleed. It’s still not really possible with the MX switch design. The Romer-G switch was the only way to get a nice bright legend with no light bleed.
