APC-7
January 24, 2021, 5:14pm
1
Hi keebs!
I’m looking for a barebones hotswap board that I can use to test different MX-footprint switches in daily use.
Here’s the checklist:
5-pin hotswap sockets
TKL or full-size
ANSI layout
solid build quality
decent stabilizers or easy to remove shitty ones
Bluetooth and RGB not necessary
I want to be able to just buy it … crazy, I know!
Any ideas? Please let me know!
One of those drop ready to ship keyboards like the ctrl might fit the bill … can’t confirm that it’s 5 pin
Isn’t Dorp known to have boards with 3 pins?
Dr.Doof
January 24, 2021, 10:27pm
4
here ya go: https://flashquark.com/?product_cat=keyboards&s=tkl&post_type=product
two wireless options from flashquark, both decent boards in terms of features and build quality
EDIT: also yes dorp is basically 3 pin exclusive
APC-7
January 25, 2021, 9:47am
5
Thank you all for the suggestions!
I think I’ll go down an entirely different road, though. After discovering that there are pin sockets available that fit the vias on my Filco Majestouch 2 PCB perfectly, I’m going to convert it to hotswap.
