It would be similar in viscosity as long as you dont add too much of the 1XX product. Also you can use that to lube topre, just be aware that mixes of Kryrox can & will separate eventually.
My preferred lube for Topre has been Kinetic Lab’s Carbon GS1. I’ve used it on p much every board and have been very pleased with the results. I do still use 205g0 for stabs tho
I currently have only 205g0 and tried lubing HHKB very carefully applying a very small amount of lube but could not make it work, 205g0 is just too thick. I had to remove the lube completely (basically making it stock again) in order to make the switch work properly without any stickiness.
I’ve read that some people use 205g0 to lube their topre sliders/housings with success and I just cannot imagine how is that possible.
ok thx a lot
