Possible to Save this GMK Spacebar?
What do you think would be a fair price for a GMK set missing the space bar? I thought $50 was a reasonable discount. Do you think it should be more?
Or, do you think the entire set is worthless, even though there is another usable 7u space bar?
Personally, I think the price is fair as long as everything else is in good shape. Before I went to ergo boards, almost all of my builds used the 7u spacebar.
Having one spacebar effectively doing the worm does rule out any buyers that would need that spacebar, but for people who don’t, the price is great
Just so we’re clear, did you bork a 6u spacebar, or a 6.25u spacebar (i.e. the boring standard one)?
More generally, $50 off is around what I’d personally expect off any used set available new from vendors for $130, but for someone willing to consider it at all, I don’t think the one lost spacebar makes it that much lower. Frankly, if it’s a 6u, it barely matters. If it’s a 6.25u, it does reduce your potential audience quite a bit. In the end, it’s a small and somewhat inefficient secondary market; it’s worth whatever you can get someone to pay for accurately described goods. :slight_smile: Saw you got a nibble. Good luck!
