I have a 1up60RGB PCB that I’ve finished with Box Royals and programming it was fairly straightforward, but for some reason, the Caps Lock LED is off when the others are on.
I flashed the default file and Caps Lock will toggle the LED, but if I toggle it on and then flash a new custom hex file I made (with a function layer key in place of the Caps Lock key) - the Caps Lock LED is still off.
Am I missing some sort of macro or line of code that would toggle all LEDs on and off at the same time?
I have the backlight toggle bound and I can toggle through layers of brightness and on and off, but the Caps Lock LED always stays off as if it’s still linked to the Caps Lock key - but my hex file doesn’t have any code for a Caps Lock LED toggle.
