I do design/cad/video/audio, I use shortcuts 95% of my time and the rest is typing emails.
Work on macs past 10 years, the placement of cmd button right under X is engrained in my muscle memory. I want a MX board that has a layout with one modifier right under X or 0.25u shifted to the left. All boards I’ve seen have it at least 0.5u shifted. Tried that, strains my wrist.
Work is funding my home office. I can spend more than 200 but would get back just 200.
Found one board that I like the layout of but it’s hideous - dustsilver d84. I generally like minimalism, not the colorful rgb galore.
Anyhow, would appreciate if you can go windowshopping with me.
Thanks, I am looking for 75%, but FRL TKL works too.
I need it to be in stock for sure.
Looking at gmmk pro (in stock locally for 150usd) - switch for modifier left of space is in the middle on z and x, so 0.5u overlay. There’s no way to change that, so unfortunately not all modern boards have the 0.25u shift option.
If it were me and I hadn’t fallen into the ergo pit I’d just get a Realforce or HHKB. Modding isn’t necessary and you’ll never think about your keyboard again for probably the rest of your (read: you and your children’s) lifetime.
I think the options are more plentiful than what has been discussed here - Tsangan layout 60%+ will have a mod at 0.25u left-shifted from X. So pretty easy to find something that’s a custom MX keyboard. No shade at HHKB (I really like mine) but, if you want to experiment, MX is a better platform to do that and you have tons of options
edit: most modern 60% non-hotswap keyboards will have Tsangan as an option, so keep an eye out for that
Only Realforce R1 has modifier shifted 0.25u. On R2 model, the shift is 0.5u. Too bad R1 is not available anymore.
But there is a mac version of R2 here with 0 shift.
Thank you all. I want something with mx style switches, tiger80 is indeed the closest to what I want so far. In EU there are some alu versions with free shipping that just about fits the budget.
I will explore a bit more though as I have a few days to make a decision.
Any ole’ TKL will do? Honestly screw kbdfans. If you want a super regular standard custom get a brutal series board from cannonkeys. Otherwise the best keybaord for work is a standard one. Realforce or HHKB get my vote.
