DZ60 is really the best out there. Cheap, reliable, flexible layout, and QMK loved.
KBD6X R1 is nice too and has underglow (unlike KBD6X RGB) but it has issues with some cases with thick center mounting pole (like Acrylic Tofu. Aluminum Tofu is OK-ish). I don’t think its PCB designer think the design through all the case variations.
UPDATE: Forgot to add that KBD6X underglow is not as bright as DZ60’s underglow. Tested both at maximum intensity.
Not to hijack this thread, but did you ever figure out how to reset your KBD6X ?
I just got my HHKB Tofu and I can’t even figure out how to reset it or put it into boot loader…it’s way more confusing than the DZ60. Flashing that was simple!
If you mean KBD6X rev 1, yeah. I just shorted label jumpers on PCB to flash.
If you mean KBD6X rev 2, no. None of the reset combos worked and nothing labeled on PCB.
Does it have per-key RGB (rev2) or underglow RGB (rev1)?
While KBDTools (rev2 only tool) is not QMK and doesn’t have a lot of fancy features, I was able to get basic stuff like Pok3r-like arrow keys working. Kind a tedious to setup though.
Glad you got it working! I know the feeling, some PCBs are super frustrating to figure out how to program. I just went through the ringer with flashing a new layout to my RedScarfII+ ver.C & can concur it does feel awesome to have finally figured it out!
