Hey guys, can someone who has a 7U Spacebar measure the distance between stabilizers center-to-center for me please? It is likely to be 114.3 mm, but I need to know for sure to order a custom plate.
I’m at work right now, but if nobody answers this before I get home I’ll get the measurement for you.
Edit: Just got in & it looks like you got the info you needed. GL with your project!
I measured the distance in a plate file I have and it’s right about 114.5mm. Your measurement might be slightly more accurate depending on the width of the cutout.
Thank you very much for the link! Should have known myself there is data sheet.
Thanks hadi!
