I know that the anne pro 2 isnt compatible with all 60% cases
so my question is what cases are known to work wit hthe ann pro 2 PCB if any?
(besides the cases designed for it)
I don’t think you’ll be able to find a case that 100% is compatible since it uses non-standard PCB/Plate screw layout.
This one will work but it won’t be flush.
