I recently bought keychron k3 low profile blue switch not hot swappable keyboard.
I didn’t like the sound. Can I change the switches?
please can you give me a link from aliexpress for brown or red switches.
You can change out the switches, but you would first need to de-solder all of the switches and then re-solder the new brown or red switches. If that’s something you want to do, look for low-profile Gateron mechanical switches on your preferred site(s).
Here’s the link for the switches, as long as you can desolder or have someone to help you with that.
thank you
