I’m about to order a Jamon deskmat from there, but wanted to check to see if @Manofinterests, @TaehaTypes or anyone else has a code for this month before I check out. I checked some of their latest videos, but no luck.
Money is tight this week & I could sure use the little bit off my order if there is a discount code floating around. Huge thanks in advance if someone can hook me up with one!
I believe @TaehaTypes has an affiliate code for 5% off.
nk types
That worked, thanks a ton!
For anyone else curious, I also have one for this month “spring springs” for 5% off
