I realise the adoption for the Kailh choc low-profile switches have been slow, but why are there more non-standard kits for them? For example, this from keeb.io and this from gboards.com?
Are there actually any standard kits out there? By ‘standard’ I mean not ortholinear, split or ergo in any way.
I’ve been searching for a while and haven’t found any, what’s the solution to this?..Perhaps desolder an existing board that has them and solder in the switch you want?
Note that the choc switches have their own footprint, incompatible with other switches.
As far as I can tell, most keyboards that use those switches don’t use a plate, or even a case, so it’s just a PCB. That means you can easily make a PCB with any layout you want, order it from the usual Chinese fabrication services, and you are done. I can help with that if anybody is interested.
Yeah, they have different pin outs, that’s not an issue for me.
For reference, I have the HAVIT HV-KB390L keyboard and it has choc switches, can I just desolder those switches and put other choc switches on it?
Also, I didn’t know you could just make any layout anf have it frabricated. I like the idea, but I know I wouldn’t be content with just a PCB. It does seem quite tempting to try though.
The switches used in that Havit keyboard are not regular Kailh Choc switches. In particular, the keycaps are not compatible (the two tabs are closer together in Havit than in the Kailh switches). I don’t know about the footprints, but I wouldn’t be very surprised if they also somehow differed.
It’s a bit more involved, since you have to draw all the traces too, so it’s a bit of work, but it’s very simple in a program like Fritzing. More professional PCB design tools, like KiCad, require a bit more work to learn to use them.
I suppose designing a plate and a case to be laser-cut is not that hard either, and there are laser-cutting services out there too. Some can even CNC steel for you…
It’s a very clever idea, though it’s designed for a Macbook which I don’t own + I don’t see any use for it on my side. Also, this just goes to show bad the new butterfly switch is.
I saw those on Aliexpress by random chance. I’ve not seen them in any board yet, but I hope Kailhua puts them to good use because they look very promising.
I may have been wrong there, but scrolling down this Aliexpress listing, it shows the switches installed in a low profile keyboard (looks a little bit like the Apple Aluminium board). Could just be a render though, I can’t tell.
