Boardwalk Typing Sound With and Without Plate Foam
This video compares the sound with and without the mkultra.click plate foam.
Specs:
Tofu 60% tray-mount case
Boardwalk PCB
Gateron milky switch lower housing
Gateron clear switch top housing
Outemu Sky v2.1 tactile stem
Sprit 63.5g slow curved springs
Christo Lube MCG 110 lube
ePBT keycaps
(in After video) mkultra.click plate foam
I don’t really hear the difference.
I think if you concentrate on listening to the alphas and NOT the space bar, you can hear a difference. The space bar seems to sound similar in both instances. But to me, the other keys sound lower pitch and more dampened with the case foam.
