Now that the PCB group buy has ended, it is time for us to focus on the cases. These became available a couple weeks after the PCB, so that would explain the delay.
This GB will run until the end of June.
To those who have already purchased, thank you.
Pictures - All colors seen are available for all cases/plates.
Switch Plates:
- Designed to be used with either “The Short One” or “The Tall One” aluminum cases.
- 6061 Aluminum, CNC smooth surface, anodized in Gray, Black, Purple or Cyan.
- Short One plate will fit other 19mm 40% ortho cases not sold by Shark.
The Short One Aluminum Case:
- Attractive design that allows the switch plate to sit flush with the top surface of the case. Unique mounting design that utilizes all holes of the PCB/switch plate(10). This adds a great deal of rigidity.
- Will come with M2 screws(10).
The Tall One Aluminum Case:
- Weighs about 2 pounds.
- Switch plate recessed into the case.
- Same mounting system as The Short One case.
- Available in Gray, Black, Purple and Cyan.
Cost:
- The Short One Aluminum Case - $60
- The Tall One Aluminum Case - $100
- Aluminum Switch Plate - $15 (Tall and Short Plates)
- Shipping is based on weight and will increase when multiple products ordered.
