Hey all,
Made an account because I really needed some help, what cases fit the Cooler Master Masterkeys S PBT (Non-RGB) PCB? If there are any, are any under a 150 or so? Any help would be appreciated.
Hey all,
@norbauer created aftermarket cases for the Masterkeys S keyboards (same interior design shared by the Rapid-i and Novatouch). This case is commonly referred to as the “Norbatouch.”
Original, non PBT version here:
HOWEVER, you have the PBT version, which has 3 leds above the arrow cluster. He did create a version for that case, but I don’t remember what round it was.
You can find it here, currently:
https://www.originativeco.com/products/cnc-masterkeys-s?variant=19174092636229
That’s no good for you though, because you can’t just buy the case.
Perhaps you could look reddit.com/r/mechmarket to see if anyone has a PBT compatible Norbatouch housing they are willing to sell
Appreciate the help, I have run across this Norbatouch case before although its currently out of stock. I might be able to find one 2nd hand.
As for the LEDs, I dont care for them to much so I could desolder them if it would open my opitions up to other cases.
And dang with all the parts/caps/stabs/lube I ordered I shouldve just bought tht already built one. That being said I’m just getting into the hobby and would need the equipment later.
Have a great night/day!
Hey, you could always just buy the one off of originative and sell yours
True. I would like different switches other than cherries though for $285. Cherry browns arnt too bad though.
