Hello! Is there a way to create your own RGB Lighting mode?
For example I would only like to create a mode which only alternating between 2 colors for 2 sec, then goes breathing mode etc.
The short answer is “yes”, but the longer answer is:
Yes, if:
So, for example, in QMK if the board has the RGB Matrix featureset you can write custom lighting effects for a board by following this documentation.
As a note: If I remember correctly, something about VIA adjusts how boards handle lighting, so you may (maybe not?) have to choose between VIA compatibility and custom lighting effects.
Ah yes I will be using DZ60 for the board, and it should support QMK…
I’m actually eager to learn on how to write a code! Is there some tutorials of qmk basic RGB codes?
This will actually be my first custom mechanical keyboard, so I’m up on trying new things
