MX switches.
My math for the distances between switch cut outs isn’t quite matching what I’m finding in plate dxfs.
1U to 1U: 5.05mm(19.05-14). No problem.
1.25U to 1U: My math says 7.43125.
((19.05*1.25)-14)/2) + (5.05/2)
(23.8125-14)/2 + 2.525
9.8125/2 + 2.525
7.43125
1.5U with same math=9.8125mm
But I’m seeing distances slightly off. For example, the ergodox full hand dxf has 9.8425mm between the left 2 columns.
What is normal for this?
Also why do some mx holes have notches but others are just squares? Is that what I’m misunderstanding?
