Hi im just looking for some Alpaca linears switches for my new keyboard.
it’s always worth a shot, but tbh you’ll probably have better luck on /r/mm than on here
I think alpacas are going to be in-stock soon at Prime KB. @holtenc maybe you can answer?
My hope is that silents will be on by the end of the month and regular Alpacas will be available sometime in June.
thx
just buy the switches on durock’s aliexpress they’re exactly the same as alpacas in feel and sound
Thx for the tip, which color combination is this on aliexpress or do u have a link for me ?
theyre all the same
