I think this keyboard sounds pretty darn good for such a cheap keyboard ($60 on AliExpress) and the keycaps sounds good too, for cheaper than GMK.
Buy the keyboard here:
Buy the keycaps here:
https://kbdfans.com/products/enjoypbt-abs-doubleshot-mechanical-keyboard-keycaps-set-2
Sounds great! Really wanna get my hands on one of these sometime. Would be a fun one to tinker with. Such a good price
I have one on the way. It sounds good stock, but can sound even better if you use an aftermarket polycarb plate.
You can also use the tape mod and try exotic mounting options. There’s discussion of this in the Youtube reviews.
Basically, tape mod, polycarb plate, lubed aftermarket stabilizers, lubed switches, it can sound pretty decent.
Spotted the keyboard on drop as well
