Is anyone else super giggity about this low-iron frosted glass case with Klippe style standoffs? I absolutely dig when people find new use cases for unconventional materials like this. It’s innovative and a bit risky.
My clumsy quotient is far too high to consider glass. I mean, the keyboard is going to break if I drop it regardless, the last thing I want is shattered glass to contend with.
This is pretty interesting
Yeah that’s pretty lit I haven’t got a new keyboard in a while might have to pick one up
Not same
But same
Looks like the glas gives the RGB a nicer feeling to it
I’d love to get one if it was designed like Bakenoko60 which is like mount-less Tofu with ring gasket ledges. I think ring gasket may bring out the glass sound better. For bonus points, I’d change the case design to remove daughter board requirement and replace ring gasket with oversized plate padding/gasket. That’d allow existing 60% PCB and plates to be used as-is.
It says mounting like a klippe, and u can do the gummyworm in a klippe
