The Lapboard60 is a universal case for your 60% to use on the couch or bed, wired or wireless via bluetooth with support for a mousepad.
Specifications
Universal 60% stacked Acrilyc case
6 layers of acrilyc
1 Plate of Carbon Fiber on 1.5 mm thickness
it comes with 7 standoffs and 14 screws for the keyboard and plate
Aditinal 5 standoffs and 10 screws for the outside structure
It supports mousepads 22 cm x 18 cm (8.6 inch x 7.4 inch) it also comes with the piece of acrilyc to put on the hole if you can’t find the exact same size of mouse pad
Estimated production time: 2 months
-it does not include keycaps, stabilizers, switches and PCB-
You can use it with soldered or hotswap PCBs
Group Buy running time:
Jan 9th - Feb 6th
Where to buy
depressedkeebs(dot)com
PRICE: 150 USD
Other colors on my website
Proto:
