Hey @xondat, can you comment on how polycarb vs brass plate feels like vs a typical aluminum plate? I went with the 5mm polycarb plate just to go with the polycarb case but is there any real big diff in feel of the brass plate?
Brass & Aluminum 1.5mm are very close however. If you enjoy either of those, but desire something slightly softer, then I’d say Polycarbonate 5mm is the perfect pick.
@xondat Hey after thinking about it and talking to Huey a little, I think I might want to go with the brass plate instead of the polycarb plate. I’m still somewhat unsure but is it possible to change my order and is there a cutoff date to make the decision?
Reading that’s made me think. I really don’t know which I’d say is softer between 1.5 brass and Alu (in the same mount style), I think maybe brass sounds softer but Alu feels softer?
