After almost 2 years of development and planning, I’m happy to say that the group buy for XRF is live. If you have any questions, please ask away!
The Noxary XRF is a case replacement for the Realforce R1, a TKL keyboard designed & produced by Topre. You will be able to take the internals of your Realforce, and swap out the plastic case for the all metal enclosure. The included custom daughterboard features a USB C port, allowing you to connect your own cable. This is compatible with the 86u, 87u, 88u, and 89u, however the Winkeyless option will require full disassembly to remove two housings on the bottom row.
Group Buy details:
- How much? $369 + shipping.
- What colors? Blue Gray, Lightning Silver, Meteorite Gray
- Winkeyless or Winkey? Both for all 3 colors.
Specification:
- Compatible with Realforce R1 Internals
- Seamless Case Design
- Top Mounted Plate
- 6° Base Angle
- 17mm Front Height
- ~2140g Kit Weight / ~2880g Built
- USB C Daughterboard
Anodizing Colors:
- Blue Gray
- Lightning Silver
- Meteorite Gray
Contents:
- 1 x Aluminum Top
- 1 x Aluminum Bottom
- 1 x Daughterboard PCB
- 1 x JST to JST Cable
- 4 x M3 Hex Screws
- 12 x M2 Hex Screws
- 4 x 3M Bumpons
Group Buy Information:
- Starts October 28th
- Closes November 30th
- Shipping in early April
