Palmetto 60% GB will begin on Saturday, 5/8/21 @ 11 AM EST
Palmetto 60% Group Buy Info:
75 Units
First Come, First Served
Sale starts at 11am EST on 5/8/21
Check your time zone here: Every Time Zone: time zone converter, compare time zone difference and find best time for a meeting with one click
Price is $475 + shipping. Shipping will be invoiced separately when the boards are complete.
Order will through our Shopify store: https://carolinamech.com/
Paypal is not accepted.
Palmetto 60 background:
The Palmetto is a 60% unibody mounted with an o-ring gasket, featuring a thick brass weight and USB-C daughterboard. The typical tray mount screw holes are not present, but there is a center post to prevent shorting out from flex. The only screws on the board are on the weight and the daughterboard. There are large holes in the case the large brass weight fits into; once the weight is removed, this allows you to push out the PCB easily, similar to the TGR/Singa Unikorn. The name Palmetto comes from the Palmetto Tree, which is the state tree of South Carolina. Palmetto was designed by Van Dusen mfg with our assistance. Van Dusen is also machining the boards in South Carolina.
Black anodized protos
Palmetto is proudly made and finished in the United States.
Each kit includes: 1 black anodized aluminum full plate, case, raw beadblasted brass weight, hiney h60 solderable pcb, usb-c daughterboard, jst cable, 70a duro o-ring, bumpons, screws, allen wrenches
Fulfillment goal is Q4 2021, possibly sooner!
Sniper grey cerakote and Green anodized protos
Cerakote Color Options:
In order to not overwhelm our cerakoter, we will only offer 3 choices and a limited number of cerakoted units this round:
8 Sniper Grey
8 NRA Blue
8 Stormtrooper White
Sniper Grey, Stormtrooper White, NRA Blue swatches.
Anodizing Options:
40 Black by CT Anodizing.
11 Green by CT Anodizing
Green ano on 6061 aluminum is potentially streaky, by choosing this option you acknowledge there may be anodizing flaws. Comes with Green Aluminum Full Plate.
This board requires the use of Cherry PCB mount snap-in stabilizers on the spacebar and backspace in order for the o-ring to work properly.
See image below for layout options on H60 pcb. A standard 60% plate will fit this case, should you choose to use an alternative.
Please reply to your order confirmation email with what add-ons you would like, you will be invoiced for them. If you do not see the email, check your spam or promotions for the order confirmation.
Pricing below on the add-ons.
Extra Plate Options:
Black Anodized Aluminum Full $35
Black Anodized Aluminum Half $35
Matte Black FR4 Full $21
Matte Black FR4 Half $21
Carbon Fiber Full $40
Carbon Fiber Half $40
Extra PCB etc:
Hiney H60 solderable $45
Hiney USB-C Daughterboard and JST cable $10
Extra O-ring $5
Brass Weight options:
Blasted Raw
Blasted + Glossy Clear Coat $10
The default option will be a raw weight, which is susceptible to tarnishing.
Raw Brass Weight
Order here: https://www.carolinamech.com
Join the Carolina Mech Discord
Follow Carolina Mech on Instagram
Typing test from Lightning!
Typing test from Lulzthax
