A meticulously crafted PVD plate designed hand-in-hand with the tasteful black & copper PCB for increased flex lends itself to an experience so , that you will get even more #feelios from your V2 Zealios and Zilents.
Enter Xeno.
Do you fancy half plates, or prefer a more traditional full plate? The choice is yours, simply click below two images to view the product page.
Early Bird Special: $40 off your XENO order with discount code “EARLYBIRD”. Valid until Dec 2, 2018, 23:59PST.
Half Plate | Silver | Rose Gold PVD - Starting from $460
Full Plate | Purple | Silver PVD - Starting from $460
Renders with Keycaps on
Contents:
- XENO Black & Silver Storage Box
- XENO 75% Aluminum Keyboard Kit
- XENO Special Edition Black & Copper PCB for increased feelios
- 1.5mm PVD & Hand Polished Brass Plate
- PVD & Hand Polished Brass Weight
- 1x 6.25u OR 7u, 3x 2u Zeal Screw-in Stabilizers (mention preference in checkout notes). Default is 6.25u if no comment.
- Custom 3M Bumpons
- Matching accent screws to your PVD Brass Plate / Weight
- You have the option to add 85x Zealios/Zilents/Tealios/Healios to your order for +$60 (Zealios V2 & Tealios), or +$70 (Zilents V2 & Healios).
Specs:
- USB C
- QMK Compatible
- Black & Copper Aesthetics PCB by Wilba
- Factory Soldered SMD Parts
- ANSI Full Plate. WK & WKL Only
(1.25/1.25/1.25/6.25/1.25/1.25/gap/1/1/1) OR (1.5/1/1.5/7/1.5/gap/1/1/1) - Regular/Stepped Caps Lock Support
- Split Backspace Support
Total kit weight before PCB: ~2.4kg
Case Color Options:
Black
Silver
Purple
Brass Color Options:
Rose Gold PVD
Silver PVD
Black PVD
GB Open:November 26, 2018 to February 15, 2019, 23:59 PST.
Estimated shipping time frame is April-May, 2019 due to Chinese New Year Holidays during February. This also allows customers to recover from the Christmas Holiday spending.
Please note that any order changes to the XENO will require a full cancellation of the kit in order to properly keep track of inventory. Any applicable early bird discounts will be forfeited.
