Here is the manual I got from @gridishere with the Google Drive link to the different firmware versions!
I wasn’t able to get VIA working on my Bluetooth PCB even with the wired firmware, but perhaps you can try your luck ![]()
thanks so much! im going to try and hopefully get it to work with via
No problem – curious to see how it goes!
same thing happened. via can’t automatically recognise even after flashing the 3 different firmware versions… it works though if i manually load the json, i am able to change the key mappings
I haven’t gotten VIA to work with either of my boards that are supposed to be compatible - I’ll give this a try!
