Anyone running a heavier dome under their spacebar? Anecdotally or theoretically, should I go with the heaviest DesDome?
I like to run 45g alphas and 55g mods. Spacebar I can even run Des green. More than that is too much for me.
I must have no finger biceps because I removed the spacebar spring on my 660C, and it was way more comfortable to type on.
Same I took the one out of my novatouch
I also removed the spring, primarily because it was rattling. I usually don’t go heavy spacebar (I do silent instead), but I was considering playing around with it. The alternative is to put a thick ring in there (#6? #7?), which would make the spacebar “lighter” by reducing the travel distance.
I’ll get small pack of greens and thick rings and start from there.
