I want some help with choosing a keyboard. Im coming from a razer blackwidow v4 x. I really dislike razer since every time i got a product from them, it was half broken.
I basically want the exact same keyboard but for it to actually work. Floating keys, clicky, 100%, rgb backlight, and preferably a good n key rollover.
I say save some money and get a Redragon K580 Vata. It’s not insanely high quality, but TBH it’s probably comparable to the Razer, and if it makes it through the Amazon free return window, it should be fine for a good while, and it’s half the price or less. They have a version with Blue switches, but it’s also hotswap so you could get whichever one has an open-box return and put the savings into Box White or, god’s own switch, the Box Navy (LOL. if you’ve liked the Razer greens, the Whites would actually be a better choice, but… just sayin’… navies are fun). It has a similar volume roller, and while it moves them to the top bezel on microswitches, it has the array of macro keys as well. I normally strongly advise QMK or another open source firmware, but for your preferred feature set, it is what it is, and easy remapping is less critical when you have all the keys already.
Hang around, though! You may find your tastes evolve as you see more pics and discussions.
