Please help, I think my durock plate mounted stabilizer is not slotting in properly in my gmmk full size. When it is somewhat mounted onto the case, when I press the key down, it bumps halfway, and gets stuck. Any solutions?
Sounds like you have stab stem mounted 180° wrong inside the stab housing.
I’ll double check, but I’m 100% sure that I mounted the stab correctly and put the wire in the correct hole.
And as a Swedish saying goes, “a picture say more than a 1000 words” in these situations.
