Both imo, although I think between plate and PCB makes more difference.
Yeah, I have decided to try both.
Any idea of the standard thickness required for between PCB and Plate?
For the space between pcb and case, I know it’s 2mm so need for the other one.
EDIT: Nasp replied, 4mm for between PCB & Plate. He is sending me a file for me to use to get someone like MKUltra to CNC the foam for me.
OK so I think I made a mistake… I think.
Krytox GPL 205g0 is the one mostly everyone uses for Linear switches and stabs right?
Well, the only I can get off KPrepublic is g2.
Is there a lot of difference?
I don’t remember witch way it goes, if g2 has a higher or lower viskosity. Other than that it’s the same.
It’s higher viscosity… I can still use it right?
Or should I mix it up with 205g2:105g0 as 2:1?
Well, 105 is like oil right? So that would only increase the viscosity?
It will increase the viscosity?
But… 105g0 is less viscous and 205g2 is more viscous than g0… So shouldn’t a mixture reduce the over all viscosity of 205g2 since 105g0 is much less viscous than the 205g0, yet 205g2 isn’t as highly viscous from 205g0 as 105g0 is of lower viscosity?
Or can I use 205g2 directly without worry?
Well I got it all mixed up so just reverse what I said.
A mix of the two should give you 205g0.
Ah thanks!
Also a question… I am getting 5g of each. I know I will need maybe 3 to 4 drops of 105g0 to bag lube 80 springs, or almost just as much to do them manually… (any benefit of doing so manually over bag lube? All 80 can be bag lubed at same time right?).
And 205g2 for a single 2u stab.
And 205g2+some 105g0 mix for 80 housing plus stem.
Would 5g of each 105g0 and 205g2 be enough? Since I actually don’t need much of either separately and mostly need a mix of them for the stems and housing.
1g of each should be more than enough.
That’s way less than I thought… XD
Just a tiny update:
I have splurged on a GB keycap set as well as artisan cable and wrist rest.
SEND HELP
Haha, What caps will have the honor to mount your atlas?
And somehow I can’t justify buying a cable for 40+dollars, maybe cus it’s something I can do myself if I have the parts.
KAT Iron
Going for just the most base requirements.
Alphas (Currently the normal ones, but might end up going Phoenecians) and Ortho Icons.
And maybe the Salvun Cap
Ye, that would be a good match. =)
Thank you!
So anyway… As usual it can’t be my build without a few snags am I right?
So seems like I can’t get the wrist rest from Uday Works due to done snags…
Pretty bummed out…
Hoping to find a loophole to get it.
Just take a piece of steel and soke in saltwater and leave it outside, perfect match
Oooorrr… I could do a DIY and save some 200 dollars?
It’s just Uday Works worked pretty hard with me on the theme so it’s a bummer.
https://www.uday.works/online-store/Handmade-KAT-IRON-Wrist-Rest-p222905337
But honestly, that’s just some paint on a piece of wood.
