Hi guys, I have a Realforce for Mac TKL silent version.
All the keys are silent, except for the left of my spacebar is causing clacking sound whenever I bottom it out. It is really annoying me.
This is how it sounds:
https ://youtube.com/shorts/1DG0l63obP4?feature=share
Do you have any idea what the issue is and how to fix it?
Thanks in advance.
do you have any other spacebars to fit on your keyboard to figure out if its the spacebar or the stabs
looks like loose fitting spacebar/some warp. try some plumbers tape on either side of the stab (not the slider)
@insolentpotato I found out the issue. It is the issue of the spacebar.
I swap the spacebar of my other Realforce for Mac and the issue was gone.
It turns out that the spacebar need a little curve(warped) to prevent L+R sides of space bar or stabilizer stems from hitting the plate (or PCB).
