That case has some crazy tight tolerances around the keycaps, and I don’t think that they allowed enough space (no pun intended) for the finish. Most people are having problems around the arrow blocker. Mine is fine but for one spot on the left control key with KAT profile. What finish/color did you get?
GMK works well in this case with some careful adjustment of the plate. Sometimes just loosening and tightening a screw will do it. But every other profile I’ve tried has had rubbing at one of the corners or the blocker. Very crazy tolerances, indeed.
yeah, i reassembled a couple of times to see if i could get any type of clearance. but sanding the keycap down was best. fortunately i’m just using relatively cheap DSA blanks.
