Hi,
I’ve been having some trouble with my pcb. When I first tested it everything seemed to be fine until I flashed it. I made sure to use the right hex file and have the most up to date drivers but for some reason it will give me weird inputs for a single key like “ctrl + shift + a” or “ctrl + shift” and none of the other keys would work normally. I tried flashing the default layout but all it did was change the positions of where the weird inputs would occur.
I’ve used QMK for other boards with no problem but this is the first time I’ve come across this.
Any help would be great
