I’m not sure if I’ll get anything out of it or not but I’m considering learning emacs; and one of the things I know you can do is view web pages from inside the editor.
That said, how well does KT work in it?
Also interested to know as an emacs user. Also well done for considering learning emacs XD
I would suggest learning to use it first before extending the time and energy to make the sites (and everything else) work in Emacs.
Have you used Emacs before? Are you familiar with Vi/Vim?
Yeah, they’re definitely useful.
I personally use Spacemacs; a great amalgamation of Emacs and Vim.
