Sorry for the silly beginner post, but I’m really frustrated and just cannot find where to buy new, good quality screws of the size you use to attach a standard PCB and case.
When I say quality I mean something like the screws that come with GMK Stabs, with a nice sized head and good thread… when I measure those ones they are almost 4mm, however everything I find online is only 3mm and I’m suspecting they are basically exactly like the ones I want to replace…
Anyone can help me with this? European source would be great, but anyone that can send to europe will be very welcome
Thanks for answering, I guess one of the problems is that I don’t know what is the size, when I measure them with a cheap digital tool they come at 1.7mm or 0.06 inches. However I read everywhere that the standard screws for this kind of standard 60% cases is M2 that I assume is 2mm? As you can see I’m a bit confused
I bought these off Amazon a while ago though they were $4 at the time. They have served me well to replace lost or stripped screws on tray mount cases.
