Introducing the Axis, an extended number pad designed to compliment a 60% or similar smaller board. Featuring an 11-degree angle, top-mounted plate, USB type C interface, and aluminum construction, this would serve as a great addition to the setup of anyone who misses their numpad and wants flexibility with its placement.
Neat.
And not to pick on your IC specifically, but I feel like ICs posted here should at least have the same info in the first post as the GH post does. Seems like a lot of ICs that get crossposted are just a small bit of info and then a GH link where the first post there is usually all of the available info.
