We are happy to present to you Doro67, an integrated plate 65% customized keyboard set.
Doro67’s look is inspired by RAMA’s M65A. The purpose of this design to build an aesthetically simplistic everyday workhorse keyboard. To achieve consistent keypress feedback, Doro67 adopts an integrated plate that is 4mm thick, which is compatible with a few layouts. In order to achieve a comfortable typing experience with high-profile keycaps such as the SA caps, Doro67 applies a lower keyboard profile (height) than a majority of the keyboards on the market. Further, to keep a stable connection, the USB connector will use a separate sub-board from the PCB.
One key design feature of this keyboard is the 4mm integrated plate.
Features:
- 6061 Aluminum Case
- 4mm Integrated Plate
- QMK PCB
- 8 degrees slope
- USB-C connector
- 4 rubber feet included
- designed by 80ultraman (Gghi on GH)
- Manufactured by ALF
We will provide the standard 9 colors, identical to the ALF DC60 GB, with the option to upgrade to the Everest White with an additional cost. Please see below.
Progress:
Currently, the prototype PCB has been fully tested, the prototype case is with the manufacturer.
8/9/2018: CNC Prototype finished, waiting for anodization.
8/14/2018: Prototype finished. Test completed. Minor modifications will be made.
To-do list:
X. Test the compatibility of PCB and the case. Done
X. Optimize the USB connector case holes and the details of the case. Done
3. Make a deal with the manufacturer (ALF) and set final pricing (estimated under ~$250 with a set of Case and PCB)
4. Run Group Buy!
GB will be announced in ALF Discord: Discord
More images:
