Hi,
I’m really bad at writing things about my work, stuff like backstory, inspirations and such are not really my thing, so I’ll just get to the point.
This is GMK Flow
Colors:
GMK Flow uses GMK’s WS1 for the alphas, and 2 custom colors, the custom colors might change a bit, but this is the general idea
Kits:
I want to keep the set as cheap as possible, while still providing compatibility for most layouts.
The first iteration of the kits is similar to what you might have seen on GMK Minimal.
In addition to the Base kit, and the ISO + Num kit, I would also like to add a spacebar kit in the future.
Base Kit
ISO + Num
Renders:
rama.works M60-A
TGR Alice
idb 60 WKL
ION Xeno
CableCarDesigns Cypher
Thank you for taking a look at my IC, I hope you like my set. Let me know what you think in the comments, feedback is very welcome.
If there is any interest at all for this, I will be posting a google form to gather feedback.
