[IC] GMK MTNU Dasher
GMK MTNU Dasher Interest Check
Pre-Order starts November 4th
Keebtalk kind of kills the image quality, for High Quality Renders, please see here (imgur album).
Based on the Data General Dasher Keyboard and of course the keyboard from the Series “Severance”, MTNU Dasher is my personal take on this Blue Retro Keycap Set.
Interest Check Form
Original Thread on the GMK Discord Server
Geekhack Thread
Kits
Kits are now set in stone. I did go through the feedback from the IC form and looked at general pricing and came to the conclusion that separating the numpad from the base kit just isn’t worth it. After discussions with Vendors, we also came to the very sad conclusion of killing the 40s and Typist kits.
Most importantly, none of the kits (apart from Novelties) will require any new moulds. This is by design, because it will make the set more affordable. If you want to suggest kitting changes, please keep this in mind.
Base
Full Base Kit with 4-key 40s included. Note that the 3U spacebars have 3 stems instead of the usual 5 in order to guarantee DynaCap compatibility.
Novelties
Some novelties inspired directly by the show, others less directly.
International
I use QWERTZ (German layout) myself and I would never design keycaps I couldn’t really use myself, so this set is a given.
Colors
White: GMK MTNU XW1
Light Blue: Signature Plastics ABS BBJ
Dark Blue: Signature Plastics ABS BO
The SA Dasher Keycaps used the listed ABS colors, for the white I figured it’s easiest to just stick with GMK stock colors.
Board Render(s)
I will make more whenever I get the chance
Other Info
Vendors
UK: protoTypist (lead)
EU: Oblotzky
NA: NovelKeys
Korea: GeonWorks
OCE: KeebzNCables
Pre-Order Info
Pre-Order will start November 4th
Edits
  • Added 1.5u “Funct” Key to Base Kit, Updated corresponding Render
  • Remade Novelty .svgs to conform with GMK manufacturing guidelines
  • Imgur Album updated (again)
  • Added Akko Alice Render
  • Unified Numpad Kit and TKL Base kit into Base kit
  • Added J-01 Render, 3D model very kindly provided to me by Jae from protoTypist
  • removed 40s and Typist kits
  • added 4-key 40s to base
  • changed “Super” to “System” to be in line with 1U
  • removed non-homing F, J and 5 to save 3 keys
  • updated all renders based on the kitting changes
  • added J-01 and J-02 Render
  • updated Novelties Kit
  • Pre-Order Date added
Interest Check Form
More MTNU in classic colorways? Yes, please.
If it’s brown or blue I buy. MTNU looks great, so that’s a plus :blue_heart:
Dasher is such an awesome classic set. I’ve got the MT3 version and the Signature Plastics SA version. Would love MTNU.
Will the blue keys be ABS? Or that’s just the color spec?
all keys will be PBT, it’s just the color spec yes :slight_smile:
:+1: thanks!
I’m in.
IC form completed.
More MTNU is always good, and a classic is all the more welcome. Will be buying even though already have Macrodata Refinement.
Is there a price yet? Just curious as to how much is saved by not having numpad in base.
As promised, here’s the next board render, also edited it into the main post:
Imgur for higher quality
Quick Edit:
Based on Feedback from the IC form, the Base Kit now includes a Numpad.
Also here’s the newest render on the J-01 kindly provided to me by Jae from ProtoTypist :slight_smile:
Who’s here from Severance? I know I am.
Quick update:
Vendors Added, 40s and Typist kits removed, 4-key 40s added to base
And here’s a re-render of the close-up from the IC form:
Final IC update
Pre-Order will be starting November 4th
Oh HELL yeah!!
